How to Unlock Samsung SGH-S125G?
*Please verify that your phone is prompt for the network unlock code while insert a non accepted sim card in this.
Follow the steps below to unlock this
Visit:-
Official Samsung IMEI Permanent Unlock Important Select the Current...
Update the following Details
Brand Name:- Select the brand Name as Samsung
Model No or Name:- Select the Model No as
Select Country :- Select the Country from The Phone Purchased
Select Network :- Select Network on which The Phone Is Locked:-
Put E-Mail ID: Put your mail id
Update IMEI No:- After the success payment you need to open the mail id and login on to unlockninja by using the details send to our mail ID
After updating the IMEI the unlock process started on the same moment and
unlock code will be delived to your mail id in least possible time.
How to use the unlock code
On the most Brand-Models the unlock code use as below
1) Insert a non compatible SIM card to your locked Cell Phone,
2) Phone will prompt for Unlock Code
3) Enter the Unlock Code you received.
4) Phone will be unlocked Now
How to Enter Unlock Codes on Samsung SGH-S125G?
Try the following Instructions:
Make sure "Airplane Mode" and "Wi-Fi" is turned off under wireless connections if your Samsung SGH-S125G is an Android device.
Method #1:
Insert a Non accepted simcard in your Samsung SGH-S125G and power on. Once finished loading your Samsung SGH-S125G will ask you to enter a code, enter the Unlock Code
Note: Non Accepted Simcard is any simcard not from the original provider
Method #2:
Go to the dial screen on your Samsung SGH-S125G as if you are going to make a call and press: #7465625*638*UNLOCKCODE# (8 digit unlock code)
Method #3:
Go to the dial screen on your Samsung SGH-S125G as if you are going to make a call and press: #0111*UNLOCKCODE# (8 digit unlock code)
Method #4:
Go to the dial screen on your Samsung SGH-S125G as if you are going to make a call and press #7465625*638*# Once prompted for code, enter the 8 digit Unlock Code.
If Phone says, "Code Accepted" or "Network Unlock Successful" or "Not Yet Personalized" your Samsung SGH-S125G is fully Unlocked
*If you are not receiving any signal after unlocking, make sure your wireless connections are turned on after unlocking the phone. Also pull the battery and restart Samsung SGH-S125G.
i have samsung sgh-x497 mobile and the same does't asses sim as the set i got as a gift from some relative in canada
pls tell me the wayout to resolve the problem
e.mail [email protected]
my sister typed in a code and locked my phone and does not remember what code she typed in now i can not unlock my phone. how do i unlock my phone?
have tried putting in codes and did not work
