Frigidaire GLTF2940ES Front Load Washer Logo
Olivia Relatores Posted on Jan 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our 5 yr. old LTF2940ES0 reaks of mildew and is covered and stained with mildew on the inside rubber ring. It does not drain all the way after a cylcle, either. I have scrubbed and washed it with bleach and hot water and it still stinks and makes our clothes stink. What can I do?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
481
Points
The problem is the big round gray rubber seal and the ridges. I have this exact washer and had the exact problem. It stunk. There is a replacement gasket for $100+ that I purchased. (It's what the new ones come with.) It has no ridges and more holes to drain the water out of. It was a pain to replace it but it was well worth it. It is like having a new washer. We tried all of the bleaching, special powders, etc and none of that worked.
PRIMOAPPLIAN
Level 3:
  • Master 401 Answers
  • Posted on Jan 17, 2010
PRIMOAPPLIAN
Master
Level 3:
Answers
401
Questions
0
Helped
106233
Points
1126
Too much or the wrong detergent {not he} if you make sure the washer water is very hot when it first fills. put about a half cup of automatic dishwasher detergent inside the tub and do a empty load.this will get rid of most enzimes.you may want to do this a couple times to freshen your machine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
How do I get the mold on the rubber at the front of the washer off?
You can try with some propriety mould and mildew products from a hardware store like wilkinsons.but rinse machine thoroughly before attempting a normal wash.It is very difficult to completely remove these stains if the machine is old.it is likely your machine is not rinsing properly due to overfilling with clothes.try putting less in and after use wipe inside rubber with cleaner and leave door slightly open to allow it to dry out after use.Try using calgon to remove calcium buildup if you live in hard water area as this can aid the buildup of mildew.if you have children then obviously you can't leave it open.
Kenmore 3.5 washer has developed mildew around the inside lip of the rubber surround. It has always had a terrible odor. I have used bleach to kill the mildew and now leave the door open. What do you...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
1helpful
Mildew odor. We have followed directions in the manual and the problem persists. We removed the front panel of the machine and cleaned the white tube that was filled with "gunk," removed and washed the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Washer Odors of Mildew
Whirlpool duet washer stinks from using goof off stain remover on clothes
Washer is 4 yrs old, very smelly and clothes don't ring out good.Could it be the pump?
Musty smell from rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
1helpful
Washer smell
LG washing machine has AWFUL mildew smell
Same problem and I was told to only use detergents with "HE" on the front of them for high energy. the soap without HE is too foamy and hence never truly drains out and causes a mildew smell. I also purchased something called "A" Fresh that I run in the washer every 6 weeks to keep the smell out. I got it at an appliance store for about $11.00 for 3 tablets
4helpful
4answers
Maytag Nepture washer Model MAH 5500 boot mildew
The new boot replacements are anti-microbial have a smoother surface and are designed to be more resistant to mold issues with proper care. Unfortunately, there are still a lot of the old boot replacements out there. The part number for the upgraded boot is 12002533..., This part number supercedes all prior part numbers for the Neptune boot assy...Hope this helps
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
