I just got an emachine Et1331G-03w machine. I can't complete the setup for Netgear wpn111. Once I plug into USB port and turn computer on again...no new instructions pop up....help.
Try reset the memory, CPU and check the CMOS battery voltage. ( 3 Volts )
Disconnect the main harness from the power supply before any of the above is completed.
Sometime, the CMOS battery on the Motherboard goes south and sometime just re-seating the memory and CPU will be enough to bring things back to life.
Hope this help you.
1.open up the PC, insert the HDD into a free HDD slot, clip/screw it in. 2. plug in data and power cables for new HDD 3. set main HDD jumper to master 4. set new HDD jumper to slave (middle pins)
If you mean your cdrom drive wotn stay close, what can happen some times is the actually cdrom unit it self has shifted back inside its rack. try opening case and loosing a few screws here and there and shift it forward. make sure nothing has got stuck inside of door tiny bit of paper or anythign can cause it. hope this helps
