Starlite Skyworth  SLC1551AW 15 in. HD LCD TV/DVD Combo Logo
Posted on Jan 17, 2010
I need a dc power cord for my skyworth tv..can't find one
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1019
Points
Just buy any 12VDC power supply with 5A rating and then just change the connector with the same size on type.
2 Related Answers
Anonymous
  • Posted on Apr 21, 2009
SOURCE: dc cord
i just found a power cord took me like 3 months but heres the web site LCDPAYLESS.com make sure its a 6 volt charger though and the guy is nice, i paid almost 80 dollars and it was here within a week any more questions j hit me up.
CoppellTVRepair.com
  • 778 Answers
  • Posted on Nov 07, 2009
SOURCE: hey i have a skyworth SLC1551A and i have no power cord at all
It's not just a power cord, it's a power adapter.
I could not find what DC does it convert to - please read on the back what input voltage does it take (probably 12V) and how many watts.
Then your closest electronics store (best) or RadioShack or even eBay will do.
1helpful
2answers
Skyworth tv has software problem
Hello Joyce, it would be nice if you indicate which Skyworth TV model you have
For what you say, you might need a firmware update, or try to leave it disconnected from the power network for 10 minutes and reconnect it, if it stays the same, try to update the Firmware, enter the Skyworth page, look for updates by the model of your television
To download the update use a new flash drive, once downloaded, put it on your TV, disconnected from the power network, then connect and wait for it to do the whole process, when it finishes updating, it should turn on, as it always does.
If that does not happen, I suggest you consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Joyce, seria bueno que indiques que modelo de TV Skyworth tienes
Por lo que comentas, podr?a necesitar una actualizaci?n del Firmware, o prueba dejarlo desconectado de la red de energ?a por 10 minutos y vuelve a conectarlo, si sigue igual, intenta actualizar el Firmware, ingresa a la pagina de Skyworth, buscas actualizaciones por el modelo de tu televisor
Para descargar la actualizaci?n usa un pendrive nuevo, una vez descargado, lo pones en tu TV, desconectado de l red de energ?a, luego conectas y esperas que haga todo el proceso, cuando se termine de actualizar, deber?a encenderse, como lo hace siempre
Si no sucede eso, te sugiero que consultes a un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
1helpful
My skyworth 32E8A has no picture but have sounds. what seems to be the rootcause?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Hey i have a skyworth SLC1551A and i have no power cord at all my brother give me the tv and he had lost the power cord i just need to find a cord if you can help me just email me and in subject put...
Skyworth 32l08hr is no power
your tv power board is burn and is better change power board or take ur tv ur tech.person
4helpful
2answers
I need codes for a skyworth tv
I'm sorry, but to help you, we need to know the brand and model number of your universal remote. Thank you.
Dc cord
Samsung ltm1755b dc cord missing/need replacement
You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
2answers
Dc power cord for sansui tv
You may be able to order a new cord from Fox International 888 369 0304.
2answers
Dc power cord
It should show it on the old cord, or on the DC jack on the TV set. A little diagram should be right by it.
Top Starlite Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Starlite Televison and Video Expert? Answer questions, earn points and help others
