SOURCE: Remote signals
If you tryed a universal remote , that remote should have at least worked the volume and the channels selector. It could be whats called a remote sensor assy thats mounted up toward the front of the set on the inside between the buttons. Its not really a user changeable part as there is soldering involved to replace the sensor. Realisticly, the correct way to trouble-shoot this set is to look at the data or logic line coming out of the remote sensor with an osilliscope to see the data and if it goes all the way to the microprocessor IC. If it does and no remote operation happens then the Micro's bad. Theres way to much Hi-voltage in these sets for a handi-person to tinker with, and its advised that a tech take a look at this set for you . Sorry I couldnbt be of more assistance. Good Luck
SOURCE: Prima Tv problems
some of the tact switch of your tv are defective,or stock ,if you know how to solder, change all switches but be carefull of short circuit
SOURCE: remote not working
possible bad handunit. to ck hold up to am radio tune to700 push remote buttons if working you will here buzzing. if not try universail remote.
