Thanks for the info. I downloaded GIMP though, but have not been able to make it work with the zoom browser that I loaded from Canon...I know that it's operator error, but any more information you could give me would be appreciated.Thanks for the info. I downloaded GIMP though, but have not been able to make it work with the zoom browser that I loaded from Canon...I know that it's operator error, but any more information you could give me would be appreciated.
You can't post conmments that contain an email address.
Yes... There are many such softwares in market.. for free toooo.
I think your camera too must have option in ur camera itself, to take the photo itself in B&W.
Chk that to. :)
Yes, you can. There are software packages out there that will allow you to edit images in many ways, including turning a color image into a black and white image. Some are commercial software, and some are free. One such free package is called GIMP, and it can be found @ www.gimp.org.
The unit has a color controller PC board that switches between BW and Color. The fact that you still show color at all indicates the circuit is complete and the BW exists independently by itself. In some cases, the problem is due to connecting cables. Change out the current set and see if that presents a solution. Make certain all connections are firm and tight. Other than that, internal data switches pose a problem and the circuit needs to be traced using test equipment to locate the problem.
You will need to replace the empty color cartridge to get the flashing to stop.
However you should still be able to print in BW. Check that the applications you are running are set to BW and not color in the configuration menu. That should permit you to print in BW only.
you can try to take out the color cartridge and set your printer settings to use blank ink or print in black only, then try to print again. Feel free to rate if this was useful/helpful.
my canon mp250 won't print color photos it does well with BW but not color. I took back the first one I had did the same thing now the second one won't print color photos off the internet. what did I do wrong? Both inks are brand new.
please you got to printer preferences select it then show a manu you select color select print in color and print if you are not succed you change a color cartridge
You don't have to replace them as a set unless there both empty. You could try resetting the printer by unplugging it, wait 30 seconds, replug it back in, and turn the power on.
