The bacteria in the washer part are causing the smell.
Give the inside a good wipe round with a damp cloth to remove any visible residue.
Leave the door and soap drawer fully open so that the inside dries out after a couple of days; that should fix it.
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
The smell of rotten eggs normally means you have some water that has been sitting arround awhile and has gone bad. You may have to unplug your machine and remove the front cover to take a look arround the inside of your machine to see if any water has leaked out and has puddled up. You may also have something caught in the drain pump's filter, which may have gone rotten from sitting around too long. This filter is easy to unscrew and gain access to once you have the front cover off. Make sure you have lots of towels or a wet vac handy when you unscrew the filter cover.
I had this problem and found out there was something stuck in the drain hose. It also made my clothes smell sour. Unhook your drain hose stretch it out straight, run water through and maybe snake it if need be.
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
smell of rotten eggs in beko wm6167W when front drain removed
