If you put the SD card into your computer and then run the USB cable from your device to you computer you can transfer these from your "computer section" on your laptop/computer.
Download the pictures from
the scanner to the computer
or remove the sd card and put into a sd card reader connected to your computer and manually delete or transfer the pics
This should do it for you: Insert the SD card into your laptop or computer. In the SD card go to "New Folder" name that folder "DCIM" in the "DCIM" folder create a new folder. This one you will name "101KC190" (I'm pretty sure you have the Kodak Easyshare 190, correct?) Now, transfer all of your pictures into "101KC190." Insert the SD into your camera and it should work. email me if you need to [email protected]
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on.
To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Hi there. Yes you can put a few pictures on the SD card, you can transfer pictures back and forward while the camera is connected to the PC or you can transfer them via a card reader.
when u insert card into PC, a window pops up close it, then open the my computer, double click the removable disk (J) if this 1 does not open D click another removable disk , once it opens, open Ur pics, then left click the pic and hold the left button and drag the pic on to the open window u opened for the SD card or right click the pic and copy the past it in the SD window, hope this help
If you have a micro SD card that has an adapter for your computer you can plug it into your computer and open it inside an explorer window and drag and drop pictures from your computer folder to your picture folder on the micro SD card. You can definitely do it. I just did it for a friend of mine and it works perfectly. That's why they sell the micro SD cards with the adapters for your computers...so you can transfer things back and forth. Mine is the 8GB Kingston that comes with adapters from micro to mini to regular SD card and to USB port. I bought it from Newegg.com for under $20.
change the pic format options in the camera to read *.jpeg intead of *.raw
if they are in jpeg maybe the computer dosn't understand the way the camera formated the sd card mine dose the same thing when i try to tranfer images from my aiptek dzo-v50 without the camra i just get card read error
