Question about Dynex 32 in. LCD Flat-Panel HDTV
I connected dvd player to dynex 32 inch tv. what
I connected dvd player to dynex 32 inch tv. what setting do i put tv on to watch dvds
  • Anonymous Mar 19, 2014
    trying to connect my rca tv converter box to the dynex 32 inch tv
    President:
  • Dynex Master
  • 1,779 Answers
You should be connected to the AV input 1 slot. Change the input on the TV to Input 1
Posted on Jan 17, 2010
6ya staff
SOURCE:
Trying 2 watch dvds on my 32 in funai tv cannot down load user manuel
do you have a hdmi cable connected to the tv?
what are you using for a dvd player?
Feb 05, 2016 | Funai Televison & Video
I have a Sylvania 32 inch DVD not reading the DVDs what's wrong???
How To Fix a Portable DVD Player That Is Not Reading or ...
? 17:12
https://www.youtube.com/watch?v=ucNedtR256g
Jan 18, 2015 - Uploaded by orly lando argallon
How To Fix a Portable DVD Player That Is Not Reading or Loading Discs. ... 2:32. How To Clean A DVD ...Missing: inch
Amazon.com: Sylvania SDVD9805/SDVD9805-C 9-Inch ...
www.amazon.com/Sylvania-SDVD9805-SDVD9805...
Amazon.com, Inc.
Rating: 2.9 - ‎916 reviews
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player. Sorry .... 5.0 out of 5 stars32+ hour car trip ... One remote does not work on both, only works for the one it came with. .... Garbage, 3 months in the first of the two DVD players stoppedreading the DVD's so we only used the one and now 5 months in the ...
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen ...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player at Amazon.com. Read honest and ...
Jan 20, 2016 | Sylvania Televison & Video
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
Dynax tv and dvd player troubleshooting
It may just a dirty laser pickup. You can try using using a laser cleaner cd which can be purchased from most electronic retailer.
Jan 10, 2010 | Dynex 20" TV/DVD Combo
How do I hook up my dvd player and WII system to my Dynex 42 inch LDC flat panel tv so they are both in color, what inputs do I use ?
Allot depends on your DVD player and WII. Since the TV is a color one unless the movie your watching on the DVD player is B/W it will play in color, same with the WII. If your DVD player supports HDMI then select one of the HDMI ports on the TV (there are 3) same for the WII depending on what outputs it supports select one of the corresponding inputs on your TV. The user manual shows several options for various components and should be of some assistance in your connections.
Nov 14, 2009 | Dynex DX-L42-10A 42 in. LCD TV
TV channel shows up behind the picture while watching dvds!
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Oct 24, 2009 | Dynex DX-L32-10A 32" LCD HDTV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
2nd set of a/v jacks doesn't seem to work
I have a Dynex 32 lcd, I am not positive buy I think one of the A/V jacks is input, and the other is output. To be sure turn the
TV so you can see the side clearly. There will be writing on the side of the TV that should explain which connections are what. i.e. input, output etc...
Dec 27, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
How can i watch dvds on this old sanyo tv?
does your tv have a scart socket or is it pre scart, if it does, and you connect the dvd player via the scart then the tv should auromativally switch to av when the dvd player is switched on. failing that, if you have no scart, then the only way you can watch dvd is by connecting a flylead from dvd player to tv, (take out antenna and put it in that socket) and then start a search if you can, normally the buttons for this are behind a flap somewhere on the tv. if you have no scart or a way of tuning tv, then i dont think you can watch dvd through that tv
Sep 06, 2008 | Sanyo DS24205 24" TV
Dynex 32 in. LCD Flat-Panel HDTV Logo
760 people viewed this question
Top Dynex Televison & Video Experts
Vitally Alcher
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
