Question about Whirlpool LSR5132PQ Top Load Washer
How do add more transmission oil to a whirl[pool washing machine?
  • 401 Answers
You have to remove the transmission and open it up. If it leaked out, you have more problems like worn seals, etc. that would need replaced.
Posted on Feb 14, 2010
6ya staff
SOURCE:
Washing machine knocking on spin cycle
Unbalanced washing causes that. If it worries you, open the door and redistribute the wet washing.
Oct 21, 2017 | Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
My whirl pool 1400 has stopped working the
Them washer are what you call high efficiency washers.HE. They only use 1 gallon of water to wash them clothes. You go adding more than a teaspoon of soap and that washer is gonna have a cow. Over a period of time that soap gonna build upb50e111.jpg so much the washer is gonna just give-up the ghost. If you know you use the correct amount of soap there could be something in them pump.You need to remove the service panel41b08ad.jpg and take a looksee at that tech sheet and see what it say about them light flashing. While you at it you may as well remove that cap6349b09.jpg and clean out that filter. d081835.jpgThat might put yall back in business. That tech sheet will be in there by that white box which is the motor control unit. The other stuff that the tech sheet error chart might reveal is located on the topside.539a7ad.jpg Good luck on dat repair mon ami.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 06, 2010 | Washing Machines
Seal a round shaft of transmission leaking what oil does the transmission require
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive washer.
See the following Whirl[pool parts list for their commercial washers although the consumer models use the same transmission and parts.
The part you need is probably the 3349985 Seal, Gearcase
Cover, a relatively cheap part.
I've found that basic 80-90 weight non-detergent gear oil ( available at auto parts stores) seems to work well. It's certainly less expensive than the gearcase oil from Sears.
Feb 12, 2010 | Kenmore Washing Machines
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
F1 code
well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LSR5132PQ Top Load Washer Logo
140 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
