Sony KDF-E60A20 60 in. LCD HDTV Logo
Posted on Jan 17, 2010
Sony 55 lcd. model #KDF-55E2000. NEED PROJECTION LAMP. what is the part number for replacement lamp?
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
5109
Points
25
XL-2400 is a suitable replacement
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Power light flashes green likes it turning on then flashes red 3 times. I just replaced lamp Sony Grand Wega KDF-55E2000
3 blinks should on this model mean "LAMP DOOR IS NOT CLOSED" BUT IT really means something else.
Can I assist you?
I can tell you how to prove this or not and if proved it is a simple and not expensive repair..
SD TECH
My projection tv keeps on turning off and on bi itself every 20 sec any solution ?
Question shows it is Sony KDF-55E2000 lcd rear projection that has lamp inside as back light source, when this lamp reaches end of its working hours life, it starts such problem.
If lamp has not been replaced in last 2-3 years, then replace it to solve this picture issue, lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp from nearest Sony Store for good picture in tv.
Thanks.
2helpful
2helpful
2answers
I get a red and yellow bar at the top of the screen
this problem has to do with te optics in the tv...not the lamp. I had the same problem, even after replacing the lamp. I called sony & they are replacing the tv with a 2010 Sony Bravia 40'. Free! For a fee of $325 I could have got a 46" or for $725 a 55". I went with the 40". Try working it out with sony. It worked for me and only took a 5 minute phone call. Good Luck
2answers
HOW TO REPLACE THE LAMP ON MY SONY LCD PROJECTON
Lamp is a user replacable. You can follow the instructions listed in the Manual. Click on the below link to open the Manual:
http://www.docs.sony.com/release/KDFE55-60A20.pdf
How do you replace the projection lammp?
I will forward a link to a page where you can find the instructions on replacing the lamp of the TV.
http://www.docs.sony.com/release/KDF42-46-50-55E2000.pdf
8helpful
2answers
Sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
