Posted on Feb 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual brother printer scanner copier dcp150c
  • 7 more comments
  • icegirl2425 Apr 21, 2008
    polaroid p310
  • Anonymous Oct 01, 2008
    Will not print. Stated Unable to Init. troubleshooting, user guide and routine maintence
  • greelyne78 Nov 26, 2008
    my printer can't be turned on even if its plugged. what could be wrong with it?
  • Anonymous Feb 05, 2009
    Everytime I go to print something it gives me the following LOAD MPF PLAIN 024-969. The print has paper. What the hell!
  • Anonymous Feb 09, 2009
    I don't have a print on my digital screen and printer does not print any documents. I have copy,photo, fax, and scan
  • ahmed abdou Feb 24, 2009
    head lift problem
    head lift Sensor is not detecting the movement from headlift Cam
  • Anonymous Mar 09, 2009
    it says to select the program to launch for this action. what so I launch?
  • Anonymous Apr 03, 2009
    how can i download the Epson 7800 user manual we have just bought it 2nd hand and have no manual.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2292
Points
My printes is saying that it is unable to print . It is asking me to see trouble shooting and routine maintenance chapter.
roxxy63
Level 1:
  • Posted on Dec 02, 2008
roxxy63
Contributor
Level 1:
Answers
Questions
0
Helped
2292
Points
My office jet all in one wont scan a document to my computer
it reads:no scan options refer to product documentation to troubleshoot i dont have the maual has anyone had this problem ?
can anyone help
A
Anonymous
Forgot my security code. How do I reset it?
Anonymous
Level 1:
  • Posted on Jun 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2292
Points
I HAVE A XPSP2 OPERATING SYSTEM WE HAVE NOT INSTALL DP1520PANASONIC PRINTER ON NETWORK
PLEASE HELP
jayamuni
Level 1:
  • Posted on May 05, 2008
jayamuni
Contributor
Level 1:
Answers
Questions
0
Helped
2292
Points
My printer is broyher dcp- 130c. the display says check out the user manual problem 34. please any one have solusion or a manual . please help me. [email protected]
Anonymous
Level 3:
Master:
Sergeant:
  • Master 440 Answers
  • Posted on Feb 11, 2008
Anonymous
Master
Level 3:
Master:
Sergeant:
Answers
440
Questions
Helped
159715
Points
1170
What problem u having with it manual on ther website brother.com what would u like to know
DCP150C User's Guide 46
If you're looking for the user manual for this unit you can download it from this link, just click HERE.
Printer USB Cable un recognized DCP150C
You need to isolate the problem. You tried using multiple cables and reinstalled the printer driver several times, but you never mentioned that you tried connecting the printer into another computer. What if the problem is the USB port of the computer and not the printer cable?
Try connecting and installing the problem printer into different computer for testing purpose only. If it work, then the problem is the USB port of the computer. To fix this, try updating the USB driver of your computer.
If same problem occurs using another computer, then you need to contact the manufacturer of your printer. I've heard this problem before and I don't have an update if there's a fix with it.
Have a great day!
1helpful
Clean unaible48
Unable to clean means that the waste-ink "sponge" is full. If you've already checked for small paper part (which is very unlikely, yet possible, to cause this error message), the error is mechanical. Unfortunately, that's not something us users can change, but the machine would require to be sent to service. So if your machine is not within warranty, I'd doubt it'll be worth the service cost.
Actually, there is a possability to order new parts, changed them yourself and enter service mode to reset counters.. But if it's worth it, good question.
2answers
Brother Printer DCP150c
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
3helpful
2answers
My Brother DCP150C printer's magenta color did not work
try to turning on your printer then after that press ink management find the cleaning press ok.
then press the arrow down to find color then press ok.wait a moment after finish cleaning
make this 3 times...
3helpful
Lost my driver to install DCP150C what can i do
Hi Buddy!
Drivers and manual are available on the the Brother support site! Go to http://www.brother.com/index.htm, click on Software download Select your country then model of printer.
Then download the driver and to your pc.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
k24674
ADMIN Andrew
ADMIN Andrew
