Kodak EasyShare P850 Digital Camera Logo
Posted on Jan 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kodak P850 do not accept SD cards 4 or 8GB, error message state that memory must be replaced. No way to format the SD in camera. How can I do that camera accept the SD card
  • Anonymous Mar 22, 2014
    how do you format the card
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Jan 18, 2010
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432531
Points
622693
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
blackbear94
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Aug 17, 2014
blackbear94
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
8539
Points
56
P850 max is 2 Gb (NON SDHC). P712 will accept 4 Gb (NON SDHC).
Dale Gildner
Level 2:
Sergeant:
  • Expert 186 Answers
Dale Gildner
Expert
Level 2:
Sergeant:
Answers
186
Questions
8
Helped
57110
Points
504
Hello. Try a 2GB card I have a Kodak P880 and the card size limit for it is 2GB.Yours probably is too
builderdale
2answers
I just opened a brand new SD card and tried to use it with my P850, but when I insert the memory card it says "Memory card is unusable. Insert new memory card." I've tried formatting and...
If you just purchased this camera, you can try phoning place of purchase or make a trip there. It sounds as if the software in camera may be messed up.
2answers
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
1helpful
I have replaced the battery and memory card, the camera keeps saying I need to format the card, but then it says it is formatting, then gives another message saying the card needs to be formatted....
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
2answers
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
2helpful
Memory card not recognised
The P850 is specified to use SD cards, not SDHC cards. SD cards max out at 2GB.
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
3helpful
It says the memory card needs formatting but when i go to format it this error occurs, FILESYS ERROR e00100
The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
Standard SD cards use FAT - which has a 2GB limit.
SDHC cards use FAT32 - which has a limit of 32GB.
Stick with 2GB or smaller standard SD cards.
9helpful
2answers
Format Memory Card Error
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
Kodak p850 Help!! error code
also having same problem after 18 months of no problems. As well, camera will not read memory cards which I have used in this camera almost since new. Format card, still no read. Sometimes when I take first photo, lens retracts as though camera is powering off but then changes it's mind and is o.k.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
