NO THIS UNIT USES CONDENSED DRYING AND WILL WET THE CLOTHES BEFORE IT EVEN TURNS ON THE HEATER. BASICALLY YOUR COMBO USES STEAM CIRCULATION THRU YOUR CLOTHES. AS THE SMALL WATER PARTICLES IN THE STEAM MOVE THRU YOUR CLOTHES IT COMBINES WITH SMALL WATER PARTICALS IN THE CLOTHES(THINK OF 2 WATER DROPS COMBINING ON YOUR WINDSHEILD AND HOW THEY ABSORB TOGETHER) WHICH RISE TO THE TOP OF THE TUB AND COLLECT INTO WATER AGAIN. THEY THEN ROLL DOWN THE SIDES OF THE TUB AND COLLECT AGAIN AT THE BOTTOM TO BE PUMPED OUT. BEFORE THIS PROCESS EVEN STARTS THE UNIT WILL ACTUALLY ADD WATER TO GENERATE THE STEAM. MOST PEOPLE FIND THAT IF THEY WANT TO JUST FRESHEN UP SOMETHING, IT WILL END UP DRENCHING WET IN THE FIRST FEW MINUTES.
SOURCE: Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
SOURCE: Malber 1000 Washer Dryer--Dryer doesn't heat
If this is still a problem, where is the red wire attached. Can you send a photo?
SOURCE: Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
SOURCE: 8 year old Malber non-vented washer/dryer
It depends on the machine and if it's in good shape a new set is going to cost you $1200.00 a pump about $100.00 plus labor Its really up to you if you can afford a new unit or not. You may want to ask the repairman if he thinks the machine is good enough to keep, If there is any hoses or belts since he has it a part it will save some labor and would be some preventive maintenance may lube rollers or anything else he might see. But the guy working on it would be able to see if there s any metal wear or wear on rollers and could give you a better answer than we could.see may see something that may be make it not worth it. hope this helps and thanks for using fix-ya.
SOURCE: washer malber wd 1000 locking
Sorry but this forum does not supply parts, part numbers or other details direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
