For a mic like sennheiser ME66\K6 prof.mic.you have two options.
What might cause the blinking of the light,might be the battery,cause it functions in two ways,either by battery or by phantom power that needs to be activated by +48v power phantom on your mixer before it can work properly .
So you will do is either you get a replacement of the battery on get a mixer that has +48v power phantom power.
It calls for a stereo input jack? I'm not sure but I think It is probably calling for a 1/4 unbalanced input jack , keeps your signal mono. so if you are only getting the bridge pickup. You might check your position switch. and or your lead pick up. simply take the designated wire from the lead pick up and hook it up where your bridge position pick up is connected. (disconnect that first) if you get sound, then it just may be your switch. if you get nothing? check to make sure you have your ground correct and he lead wire correct. If these are active pick ups? you''ll need a battery source. if stil get nothing. your pick up may be bad.Thats a reads digest troubleshooting explanation. check your basics first. good luck
your starter sounds like its sticking. the carbon brushes in older models wear down and need to be replaced. or, starter needs replacing/reconditioning. first try to tap lightly on the starter with a hammer then try to turn the key(bring hammer with you!!) failing that you may need to get it checked. you could try a hill start to see if it is just the starter.
have you checked the altenator? is the belt on the altenator? most places like auto zone will check it for free. advance auto also checks them free. sounds like after it dies and you park it for 8 hours the battery picks up enough to start it and run it for what?30mins top? with lights on 15mins or less? you're altenator most likely bad or belts loose or gone. hope this helps!!
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
on1986 toyota both headlight share common ground. first chek bulbes and make sure they are o.k.
if bulb are fine check ground for headlight (black wire) if o.k you need a headlight switch.
First off your blinking battery light means you have a faulty battery and you need to have that replaced. Call tech support and they will replace that for you. Once that is charged up all the way then hopefully the camera will work properly for you. If not try resetting it.
