Check your power supply and power cable and check your monitor cable if its not damaged..or try your monitor to another computer..
Sounds like classic symptoms of capacitor failure.
Old thread, but in case anyone else is still looking for an answer, the problem is probably bad capacitors on the power board. There was a world-wide problem with capacitors in the early 2000's that affected all kinds of electronics. For a good summary/review see https://en.wikipedia.org/wiki/Capacitor_plague .
Make sure the replacement capacitors are the proper size, specs (volts (v) & micro-farads (mf)) and temperature rated for 105Ā°C. Make sure to install them in the proper orientation, they have a positive (+) and negative (-) terminal. I had 3 bad ones but replaced them all. It's actually quite simple and cheap if you have basic soldering skills. If you're not sure, research soldering technique and safety. Be Safe Out There.
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
Yahoo: viivtechavril SKYPE: viivtech Mobile: 86)15989403359 Email:[email protected] ,[email protected] Website :www.szviivtech.com Tel: 0086 755-29477736 Fax: 0086 755-29410695 ADD: sha
