Question about Apple PowerBook G4 Mac Notebook
Airport card disconnected
G4 Macbook Pro. Computer has an airport card installed. When trying to open Airport from the menu bar, message appears saying no airport card installed.
  • 115 Answers
There is no Macbook pro G4 (macbook pro are using intel chips) please clarify
Posted on Jan 20, 2010
6ya staff
SOURCE:
Forgot password for macbook air
Dear Sir,
Welcome to Fixya Support
Resetting Your Password You can reset your administrator password and passwords for all other accounts. To reset your password, using a partner computer and Remote Install Mac OS X:
1 Follow the procedure for using Remote Install Mac OS X
To use Remote Install Mac OS X: 1. Insert the Mac OS X Install Disc 1 into the optical disc drive of the other computer. 2 .If the other computer is a Mac, open /Applications/Utilities/Remote Install Mac OS X. On Windows, choose "Remote Install Mac OS X" from the Install Assistant. 3. Read the introduction and click Continue. 4 .Choose the install disc you want to use, and click Continue. 5. Choose a network connection: AirPort, if you are using an AirPort network, or Ethernet, if the other computer is on an Ethernet network and you have an optional Apple USB Ethernet Adapter connecting your MacBook Air to the same network. Click Continue. 6 .Restart your MacBook Air and hold down the Option key as it starts up, until you see a list of available startup disks. 8. If you chose AirPort as your network in step 5, on your MacBook Air choose your AirPort network from the pop-up list. If the network is secure, you are prompted for a password. You can enter a private network name by choosing the ellipsis (...) and typing the name. 9. If you chose AirPort as your network in step 5, when you see the AirPort status icon indicating signal strength, click Continue in Remote Install Mac OS X.
10. Click Continue in Remote Install Mac OS X. 11. On your MacBook Air, choose Utilities > Reset Password from the menu bar and follow the onscreen instructions. When you finish, quit Mac OS X Installer. 12. On the other computer, click Quit to exit Remote Install Mac OS X.
I think it helps.Let Me know.
Dec 25, 2010 | Apple MacBook Air
I have a Powerbook G4, and suddenly my airportcard stopped workin
OSX has become unreliable.
You could spend hours troubleshooting, or simply backup and re-install from disks, takes about 40 mins
Jun 20, 2010 | Apple PowerBook G4 Mac Notebook
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
Cannot see wireless network in airport icon list
Open your airport utility (Applications/Utilities/Airport Utility). See if anything comes up on the left. If not, reset your airport and network.
Also, in System Preferences, click Network. See what it shows for airport, and delete your current network, and set up a new one. Do you have bars on your airport on the tool bar?
May 15, 2010 | Apple MacBook Pro Laptop Computer with...
Imac to finding airport express. other computer
Several steps to try.
1) Make sure your iMac Airport card is powered on. You can do that with the Airport icon in your menu bar (looks like a pie wedge), or go to System Preferences / Networking / Airport and make sure Airport is on (also, enable "Show Airport Status in Menu Bar" to get the handy icon).
2) Temporarily move your iMac as close as possible to the Airport Express. Pull down the Airport icon and see if the name of your network shows up. If it doesn't, you have a bad Airport card in your iMac. Otherwise...
3) Move your iMac back to where it was. See if the Airport icon still shows your network's name. If not, you may have a bad Airport antenna in your iMac, or you may simply have too many intervening walls or be at too far a distance.
Nov 16, 2009 | Apple iMac G5 Desktop
Hello, i recently bought an airport card off of ebay and installed it in my G4 tower (mirrored drive doors). the OS has been upgraded to Leopard. I cannot get it to turn on. When I try to configure...
Hi Kathy
What message do you get? does it say anything like "Not airport card found" or something similar.
A couple of things to check. First make sue that the card itself is fully home in the socket. Second, make sure that the arial lead is properly connected. It is really easy to think that the arial is connected when it isn't. The plug is a very close fit. it should click into place and you should not be able to get a finger-nail between the plug body and the card - if you can it's not connected.
Failing that, the card may well be faulty - sometimes happens with eBay.
Oct 28, 2009 | Apple iMac G4 Desktop
Install an Airport card in a G4 Tower
There are six models of Power Mac G4 computers: AGP Graphics, PCI Graphics, Gigabit Ethernet, Digital Audio, QuickSilver, and QuickSilver 2002. You cannot install an AirPort card in the Power Mac G4 (PCI Graphics); the rest accept original version 1 Apple Airport cards. The card is simply inserted through an opening in the PCI card guide and seats itself into a socket on the logic board. Then you attach the loose antenna cable to the hole on the end of the Airport Card. You're done.
Oct 16, 2009 | Apple iMac G4 Desktop
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Jan 12, 2008 | Computers & Internet
Apple PowerBook G4 Mac Notebook Logo
201 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
