solution for 6600 bluetooth and gallery cannot open
step 1) make a jumper (you can see the encircle terminal of bluetooth ic) then assemble the mobile,turn it onstep 2) OPEN FIRST THE GALLERY WITHOUT MEMORY CARD,THEN OPEN ALL THE IMAGES,MUSIC ETC. INSIDE OF YOUR GALLERYstep 3) TIME TO TURN ON YOUR BLUETOOTHstep 4) PUT BACK THE MEMORY CARD AND DO 2 AND 3step 5) then remove the jumper and do step 2,3,4..if still the cannot open again,put the jumper and reheat the bluetooth ic and repeat it step 1,2,3,4.I ..GOOD LUCK TO ALL WANT TO TRY! JUST TRY IT THERE IS NO RISk
your handset have a hardware problem.
the problem is with the bluetooth IC, this should be replaced.
bring your phone to a service/repair center that is authorized by NOKIA.
Bluetooth IC is not user serviceable, and replaced using special tools. And another thing, bluetooth IC is very sensitive, wrong procedure in IC replacemnet might lead your phone totally dead or not usable.
Well the problem which you are facing is due to spill of beer on the keyboard.
As the beer entered its circuit it might have damaged the bluetooth IC and disallowing it to work.While the light of the bluetooth is still on because current is flowing where as the IC is not functioning!
your bluetooth IC may be not working.you kindly checkout your bluetooth . if your bluetooth cannot open than you go to a mobile repair shop and they change the IC and gallery is also works
