Sansui DTV2760 27" TV Logo
Posted on Feb 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sansui 32 tv where are controls such as contrast etc
Tv was gift have no manual. cannot find individual controls to adjust contrast, tint etc, thanks
sansui sv 29276
Anonymous
Level 3:
Genius:
  • Master 1,665 Answers
  • Posted on Feb 12, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1665
Questions
Helped
979096
Points
3981
What are the setting calibrations for the best picture
There should be a few preset choices for you under the display menu....ex. Cinema, sports, etc...
My little cousin messed up the color configuration on my Sansui dtv 2700 (27" CRT tv) and I don't know the numbers. There is brightness, contrast, color, tint, and sharpness. The lowest number is -32 and...
These settings are depends to personal preferencess and location brightness. I would suggest to set all of them to zero and then work your way out on individual settings. Obviously this tv is an old set (that is my assumption) so it does not have a factory reset.
2answers
Color configuration of sansui tv?
The color is weird, it isn't the green or blue scale, it's just not right. The numbers for the
brightness, contrast, color, tint, and sharpness have been messed with. They go from -32:+32
/uploads/images/color-configuration-sansui-tv-34681426-4-1.jpg
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
3helpful
3helpful
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
Picture problem
It's not an adjustable problem and not all that easy to guess at either. Power supply is a usual suspect and my best suggestion would be to take it to a reliable shop for an estimate.
Bill
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
