You can read it from HERE or you can download it from the same link. To download, click "File" just below the googledoc logo and then select "Download Original". Good Luck. Thanks for using FixYa.
Hi there. look in the camera's settings to see if the flash is turned on, if it is and the flash still does not work you will need to take it to a service center for them to replace the halogen bulb.
Not likely. Unless the flash setting has been turned to off (a lightening bolt with a circle and cross through it on screen or in a menu), or to very low power, or you are in a camera mode that turns the flash off (check your exposure scene modes) this requires replacement. You could send it away for a quote through a camera store but prepare for the worst $$$
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
