Kenmore dryer 11097375800. Stopped heating everything else seems to work is it worth fixing?
My dryer for Kenmore Model number 94702 does not turn on. It worked up to about a week ago. I've done electric in my home like put in new lights and switches, and changed a fuse in the fuse box. Never attempted changing a motor, heater switch or belt. Is it two hard to tackle?
Yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
