Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1.Pull the paper tray out of the machine.
2.Pull out the jammed paper.
3.Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4.Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5.Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6.Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine. Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper.
7.Close the Upper Jam Clear Cover.
8.Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point.
Aloha,
Bill Monroe
