I have a Generac XL4000. It rill start but not run right.
I have a Generac XL4000. It rill start but unless I close the choke about 1/2 way it will not run right. The engine speed surges from normal to idle and back to normal. I evens out a little under load.
Re: I have a Generac XL4000. It rill start but not run...
If the area you live in has alcohol added to their unleaded gas, then you will probably need to rekit the carbuerator. Also check the spark arrestor for plugging up. Try to find a non alcohol, off road unleaded gas for your generator.
Please make sure that you're running the generator outside and that you've placed it in a position that's recommended by the manufacturer. I'm thinking that there is a safety protection (shutdown) being triggered by your generator because something is not setup properly.
Please call Generac for clarification on the issue: (678) 885-9751. Thank you.
check the operation of the electric choke as it may not be properly adjusted to be closed at first start
chokes(manual or otherwise) are held open until you open the accelerator/throttle to release the cam lock to allow the choke butterfly to snap closed
the problem will be in the choke area of operation
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
check that the gas converter/ regulator is operational and allowing enough gas through with out the choke
With the choke closed your are creating high vacuum in the inlet manifold that is sucking enough gas past the regulator to run on
have it checked and tested by an accredited gas fitter
hi
can you visually see that the solenoid is working by seeing that the choke actually close when the solenoid are being activated if so the fault is elsewhere .
not supposed to... only supposed to start with choke closed...Now if you mean will not run unless choke is closed I would suggest removing and cleaning the carb...
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
