Symantec Norton Ghost 14.0: Windows Logo
Anonymous Posted on Jan 20, 2010
What version of Norton Ghost provides the boot disk can do disk-to-disk cloning?
Anonymous
Level 3:
  • Master 644 Answers
  • Posted on Jan 20, 2010
Anonymous
Master
Level 3:
Answers
644
Questions
Helped
217558
Points
1886
I beleive it is the 2003 version
Testimonial: "good call "
Anonymous
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
33677
Points
54
Norton Ghost 15 helps in disk to disk cloaning. It is the latest version of Norton Ghost available in market.
Get detail information about Norton Ghost by clicking here.
How to make ghost image of windos 7.
Are you reffering to Norton Ghost? If so newer versions require that you install the software on the pc itself, from there you can select to do a full disk back up which will create a system image.
If you have an older version you can actually boot from the CD-ROM on system boot and create your image from there.
1helpful
2answers
My Hard drive has only 6% space left on it.Can i connect external Hard drive to it?
> can I connect an external hard-drive to it?
Probably.
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
2helpful
4answers
Clone hard drive (laptops) THIS IS ONLY FOR PEOPLE EXPERIENCED WITH CLONING HARD DRIVES, IF YOU NEVER DONE THIS, PLEASE DON'T WASTE MY TIME!! I use either easeus copy or clonezilla (iso file is burned...
Dear Fixit2009
do you mean clone a window or any system that is in the hard disk to another hard disk?
if you mean it, I suggest you use a ghost, because it is so easy to use and saves you time and
If you want to change your patision space in the windows system, patision magic is simple software to make the process
If you are using genuine software is better, but if you want to get free, trying to find using utorent.
thank you.......
hopefully in can help you .......
Ghost disc will not boot, not recognized as valid windows copy
If it's a Norton disk, call Norton, it should be bootable. If it's a disk you burned, it may not be a bootable system disk. Make sure your computer is set to boot from CD/DVD drive in the bios (setup) Press F2(usually, sometimes it's delete) while booting, go into setup, and make sure under boot devices/sequence that your disk drive is first in the boot sequence. Try the disk on another machine to see if it's the disk, or the machine. If it's the disk, Call Norton (if it's theirs) or have someone make another one for you.
Error Copying old c: drive w/Ghost 9
Do a disk defrag on the source drive. If that doesn't work, you may have a virus on your source drive and norton ghost is catching before getting on your destination drive.
I keep getting the message 2010
After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
Solution There are three possible workarounds to eliminate the error:
  1. Update the hard drive firmware to the latest level. Download the hard drive firmware update, and then apply to your hard drive.
    Note: This update requires a floppy disk drive.
  2. Replace the hard drive with one supported by the system being used.
  3. Use the hard drive, producing the 2010, error in the Ultrabay of the system or a docking station with the second hard drive adapter instead. The interface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potential problems with diagnostic or copy tools. There are known issues with several of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided by Hitachi GST which uses vendor specific commands on the hard drive. These may not be correctly interpreted since they must pass through the serial to parallel ATA bridge. However, version 4.00 or later of the Disk Fitness Test (DFT) will work.
  2. HDDTEST version 0.28 by Hitachi GST does not function properly for similar reasons. Instead, use HDDTEST version 0.29 or later.
  3. DOS-based copy tools may function slowly or produce incorrect output, specifically previous versions of Norton/Symantec Ghost. These versions are not compatible with the Serial-ATA interface of the Intel ICH6M chip set. Documentation on this problem may be found at www.symantec.com. It is recommended to use either a newer version of Ghost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost 8.0 or later, or to use the -FNI switch when invoking Ghost from the command prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. The hard drives shipped in the affected systems will not display the message because they already have firmware that recognizes this new Serial ATA bridge chip. However, a similar drive from an earlier ThinkPad system or an OEM drive might cause the error message to be displayed. Customers may also notice the POST error message after applying a ThinkPad BIOS update if a drive without the firmware update is installed in the system. Some early systems were shipped with a system BIOS version that did not provide this POST error message. Updated BIOS has been released to provide this informative POST error message to users.
Ghost 9.0. Backup fails due to bad sectors on c:
In my experience when i have used ghost 10, u can go into (from my memory), into options, and check mark the crc ignore and another section has to ignore errors.. now i haven't actually done a ghost back up, but a disk clone, so not positive that u will have the same options..
WD Scorpio Black 320GB SATA drive
Halarious, I had the same problem yet I used norton ghost. At least you still show 160 gb. Mine went all the way to 60 gb. Here is what I had to do to reclaim the lost. I downloaded something called "Magic Boot Disk" It gave me the whole 320 back yet have not found good cloning software yet. Magic Boot Disc is freeware avaliable at http://hddguru.com/content/en/software/2006.02.10-Magic-Boot-Disk/ Good luck cloning
When i used norton ghost it will not proceed to copy disk to disk?
now the symantec is not supporting this version of the norton ghost,you have to get the upgraded version of the norton ghost 14.0
6answers
Transferring info from one hard drive to another
No that wont work.  :)
You will never be able to copy all the files from windows.
Here is my suggestion.
Their are several programs out their to help you accomplish a disk to disk copy. I personally use Norton Ghost. Action True image is another.
This particular program i have found extremely reliable.is Norton Ghost 2003. This is a hard drive cloning software that runs from dos.
When you are running windows, you cant copy by drag and drop, all the files. Windows just wont let you move the important files.
You could purchase norton ghost 2007. That software is designed to work from windows. You can install it and then clone the running drive onto the new fresh drive.
After you clone the drive, you can just set it to "active" and switch the boot order in the bios. Or just unplug the old drive.
I can assist you in getting a copy of norton ghost dos edition, and clone the drive. However it would require direct connection to your pc, and phone support to walk you threw it once your into dos.
Top Symantec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
