Question about Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S no picture
I have a westinghouse tv model number SK-32H240S the sound works but the picture dosen't if u turn the tv on the picture comes on for 1or2 seconds and goes out again
  • Anonymous Mar 28, 2014
    tv wont turn on
    New Friend:
Its a inverter transformer, part no. sk32h2405 b070401
replace this and the picture will come back on
Posted on Apr 16, 2013
  • Westinghouse Master
  • 12,061 Answers
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Jan 21, 2010
2 Suggested Answers
6ya staff
SOURCE:
westytech
vidal chavez
  • 120 Answers
SOURCE: I have a westinghouse tv
Hello Olga, this problem is normally caused by something on the power/inverter board (normally a transformer or a capacitor). If you are technical you can open up the TV and see what component is bad, you can normally tell because the component will leak or in the capacitors case be puffy. If you are not that technical you can also open the unit and simply pull all the plugs from the power/inverter board (big brown board on the left hand side when TV is facing down), take off all the screws, and replace the whole board. I can assist you with obtaining part #'s for this board if you would like just simply send me an email with the model #, serial # and TW # all located on the back of the TV as well as a brief explanation of what the TV is doing to westytech@westinghousedigital.com. Please rate my answer if it was helpful, have a great one.
Posted on Apr 06, 2011
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
Mar 28, 2011 | Westinghouse SK-32H240S Television
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
When turning, on picture come up for 1/2 sec then goes plank,
My Westinghouse SK-32H240S television fails showing picture. Only sound can we hear but no picture.
Jun 02, 2009 | Westinghouse SK-32H240S Television
Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
May 18, 2009 | Westinghouse SK-32H240S Television
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Feb 01, 2009 | Westinghouse SK-32H240S Television
Can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Televison & Video Logo
1,101 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
