Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-)
Did you validate it? Did you actually buy Windows? If you have a certificate of authenticity (with the activation code) and it doesn't work after validating with this code, call Microsoft.
There will be a sticker on the laptop wi the product key.
It will be in the format of xxxx-xxxx-xxxx-xxxx-xxxx
Sometimes the sticker will be under the battery.
If the sticker is not on the laptop it was either removed, or you need to make a complaint with Walmart.
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
This should be a fairly simple fix. In the bottom right corner, or when you boot up there should be a REGISTER SCREEN... When it fails it will offer you the opportunity to call Microsoft. Go ahead and give them a call, let them know the type of computer you have, what the fault is saying. They may ask you to call dell and get replacement software, but since EVERY DELL ever made came with an operating system they are usually pretty good at giving you assistance.
If they dont and they force you to call dell, they (dell) might charge you a few bucks for a new install cd, or they may let you download one. Either way your problem should be solved in an hour .
See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu. When the window pops up select Device Manager. A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode. If it boots in normal mode let it detect the Display and install the drivers for it. I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
the symptom more or less feels like there is a video driver problem on the laptop. I would like you to shut down the sytem ,disconnect the Ac adapter and remove the battery from the system. press the power button for 10 seconds .
Reinsert the battery and connect the Ac adapter.
Press the Fn + Power button , to run the diagnostics.
Do post back if you see colored lines on the screen ..so that i can give you more help
