Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV Logo
Posted on Jan 22, 2010
Sony kdl-v40xbr1 has horizontal lines
Sony Bravia kdl-v40xbr1 has colored horizontal lines evenly spaced across the screen. We can see a picture, just has the lines over it. Lines are not solid but pixlely. Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1122
Points
I'm having the same problem. I have noticed on mine that the menu when brought up is clear and I can see it perfectly. The picture on all the inputs is just as described above though. BUT, like I said I can see the menu just fine. This leads me to believe that it's not the panel. Anyone have a solution to this, or at least know what could be causing it?
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
1helpful
1helpful
I own a 5 year old 40" sony bravia lcd tv, When
This sounds like what I managed to do to my screen, even though I knew better. Is there any chance you layed the screen face down at some time?
Even though you can still watch it OK, you probably have hairline fractures in the screen face (NOT the screen itself- be thankful for that- the cracks are in the screen coating). LCD screens are a very thin glass laminate with a thin protective glass-like coating. When they are laid flat (like I did to connect cables) if the screen bears any weight, microcracks develop on the front of the screen.
I am sorry to say that the effect is permanent.
1helpful
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
2answers
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
1helpful
2answers
Sony Bravia TV KDL-V32XBR1 picture
Try different cable, if you still get the problem after replacing cables, then you have a defective sygnal board (input board).
15helpful
2answers
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
