Question about Westinghouse SK-32H240S Television
Zenith DVD/VCR will not connect to Westinghouse HD TV
I can't connect my Zenith DVD Recorder/VCR to a Westinghouse SK-32H240S HD TV. I have tried all of the different connections. I am connecting the TV to a Comcast cable box using a YPbPr2 cable. I was able at one time make the connection using the Red/White/Yellow cable connection. But this does not work either. Can someone tell me what I'm doing wrong and how to fix it.
Thank you
Alex
  • alchemancer May 11, 2010
    So you are pressing the appropriate input button on the remote? If the device is plugged into the second input of a particular type, you have to press the input button twice. Or press the input button on the tv to the source you want. Is autosource on or off in the power menu? The cables are definitely good? Have you tried the device and/or cables on a different tv. I know nothing about your Zenith DVR/VCR, but just got done pulling apart that exact tv to clean some cables that made the picture splotchy, and have been using it as my PC monitor for about 7 hours now, so far so good. Drop me a line if ya want alchemancer@yahoo.com
6ya staff
SOURCE:
Anonymous
SOURCE: Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Posted on Jan 28, 2009
Anonymous
SOURCE: Need a service manual for SK-32H240S TV
They are now sending me a new TV
Posted on Jun 03, 2009
Anonymous
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
Anonymous
SOURCE: SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Posted on Jul 09, 2009
Anonymous
  • 3 Answers
SOURCE: how do i connect nintendo 64 to westinghouse hdtv and use it?
That should be sufficient. FYI the yellow is composite video, and the read+white are the stereo audio plugs.
You probably need to select the appropriate input on your TV.
Posted on Jul 21, 2009
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
What's the vesa pattern for westinghouse sk32h240s tv???
The SK-32H240S has two sets of mounting holes 75mm x 75mm VESA or 100mm x 100mm VESA mounts.
I hope this helps. The manual is available here: http://www.retrevo.com/support/Westinghouse-SK-32H240S-TVs-manual/id/2727ag925/t/2/ . You will need to enter a code to download the pdf.
May 19, 2011 | Westinghouse SK-32H240S Television
Westinghouse tv sk-32h240s after watching for 10 minutes srceen turns blue
That normally indicates that it has lost the signal from the tuner/cable box if you lose the audio as well. I'd try different inputs such as a Dvd player and see if the same thing happens. If it doesn't, then the problem could be a bad solder connection near or in the tuner or cable leading to the tuner.
Jan 29, 2011 | Westinghouse SK-32H240S Television
I HAVE A WESTINGHOUSE HD TV 23" SK-32H240S WHEN I TURN IT ON I HAVE A PICTURE FOR ABOUT A SECOND AND THEN THE SCREEN GOES BLACK
Look for Bad capacitors on power supply board they will be vented or swollen on top 220uf 10v 330uf 1000uf 16v
Oct 22, 2009 | Westinghouse SK-32H240S Television
I have a westinghouse sk-32h240s whin i retune it
No. Everytime you rescan channels it will dump any previously saved channels.
Jun 23, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Feb 01, 2009 | Westinghouse SK-32H240S Television
Can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Televison & Video Logo
141 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
