Can you help me unlock my memory card??? It's Nokia 2700.....
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
www.unlock-free.com/nokia-master
Security code lost
My Nokia 2700c-2 i put a keypad code on it and for got it can you help me out with the master reset code to input into my device ?!?!?!?!?!? IMEI# 358262/03/055118/2 can you send me the MAster reset code the type:RM-561
At fast u download a fexploar than open it,u can see (c) than u copy it to ur phone and move in ur com
Yesterday i change my security code and i forget it please help me to break this password
I forgot my security code an i want to restart it how can i do that
There is no way to break security code in nokia 2700 it needs the help of customer care
SOURCE: i have forgotten the security
Type in *#7370# and press the dial key.
It will request the security code, which is 12345 (you cannot avoid this step).
Keep in mind that all data on your phone will be deleted, and make backup if you need it.
If this helps, please rate.
Thank you
SOURCE: how i can break security code Nokia 2700 classic
Switch off the phone.
Remove the battery for 30 minutes.
Reinsert the battery and switch on the phone.
Enter the default code 12345.
Your phone will be unlocked
SOURCE: i have forgotten security code of my nokia 2700
Hello Aim,
SOURCE: how to break my security
Hello Anis,
If you want to break the phone security lock :
Switch off the phone.Remove the battery for 30 minutes. Reinsert the battery and switch on
the phone.Enter the default code 12345 or 00000.Your phone will be unlocked.
If you want to break the phone memory card security lock :
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
i forget my securti code how to break
SECURITY CODE 2700
plz..givr me nokia 2700 classic phone security code..
