Hi, why do you want to disable router password?
It is part of your security so sobody else can access it.
What happens if someone want to connect to your router or alter any settings, they could do this then lock you out of it while sensitive information is being stolen from your pc.
LEt me know what help you are really looking for, maybe i can help with what problem it is you have.
Turn off / Disable wifi in the laptopTo Enable WPA Security in the wireless network
- - Hardwire the computer and router
- - Open the router setup page ( http://192.168.2.1 )
- - Click wi fi Protected setup on the left side
- - Scroll down a little and you can find the router PIN
- - This is the number that you need to enter in the device
Please follow the below instructions to protect your device:
When wireless clients survey the local area for
wireless networks to associate with, they will detect the SSID
broadcast by the Router if the Broadcast is enabled. Do not broadcast
the Router SSID. It must be Disabled.
Note that your SSID should be set following similar rules for setting a
password, e.g. at least 8 characters, a combination of letters, numbers
and non consecutive characters.
Disabling the SSID broadcast is not a strong security setting, but it
can help prevent intruders from sharing your WLAN. Remember to save your settings.
You do not need the software that comes with any modem:
Reset the router:
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the reset button on the rear panel of the router.
1. Press and hold the reset button until the Power LED turns red (about 6 seconds).
2. Release the reset button and wait for the router to reboot.
To log in to the modem router:
1. Type http://routerlogin.net or http://192.168.0.1 in the address field of an Internet browser.
Enter admin for the user name and password for the password, both in lower case letters.
NAT automatically assigns private IP addresses (10.1.1.x) to
LAN-connected devices.
? Enable. Usually NAT is enabled.
? Disable. This disables NAT, but leaves the firewall active.
Disable NAT only if you are sure that you do not require it.
When NAT is disabled, only standard routing is performed
by this router. Classical routing lets you directly manage the
IP addresses that the DG834G v4 uses. Classical routing
should be selected only by experienced users*
? Disable Firewall. This disables the firewall in addition to
disabling NAT. With the firewall disabled, the protections If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
