Im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
My husband and I are having very similar problems with our fridge, but it's also 4 years old. Two days ago, it started to beep about every 15-30 minutes and all of the lights/panel on both sides were off. We can make everything come back on if we open and close the door and few times. But, come on really. We have had nothing but weird problems with this thing and of course my husband lost the owners manual. Don't let anyone sell you anything that isn't even on the market yet.
When the lights are working, push in the button or buttons on the door switch. If that does not make the lights go off you need to replace the door switch. If your fridge is like mine the fan sending cold air from the freezer to the refrigerator section goes off when the door is open, and a bad switch may indicate the door is open all the time. With the fan shut off all the time the temperature rises in the refigerator section, causing the alarm to sound. The switch should only cost about ten bucks. genetuck
