Dishwashers Logo
Posted on Jan 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Detergent tablet not dissolving.
I have a Zanussi Progress AAA dishwasher. The tablet I am using as a detergent is not dissolving. The dispenser door opens but hte tablet is still intact after the wash. Can you help please?!
dnkypunch
Level 2:
New Friend:
  • Expert 37 Answers
  • Posted on Jan 22, 2010
dnkypunch
Expert
Level 2:
New Friend:
Answers
37
Questions
0
Helped
32997
Points
112
Sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
southside773
Level 2:
Novelist:
  • Expert 108 Answers
  • Posted on Feb 08, 2011
southside773
Expert
Level 2:
Novelist:
Answers
108
Questions
Helped
13229
Points
245
Several possible causes - maybe door not fully opening as dishwasher deodoriser in the way - is wash pump running ok? - is water filling ok? - have you selected a 30 min rapid wash? (if you have, put tablet in cutlery basket, not soap drawer) - is top spray arm turning? - this machine relies on the spray arm to 'wash' the tablet out of the drawer - maybe holes in the spray arm are blocked.
1helpful
The recommended soap tablet does not dissolve complete although the dishwasher goes complete cycle
There are two reasons why it can happen:
1. Too much dishwashing detergent (There may be build up from before causing caking and so it's not dispensing the soap tablet)
2. You will notice a tiny spring inside your dishwasher detergent dispenser. This spring is triggered during the washing cycle and causes the dispenser door to pop open. A broken spring can prevent this from happening. If the spring is clean with no food, suds, or obvious buildup preventing it from working, it likely needs replacing.
I had a similar issue and found this website really helpful. Hope this helps.
https://www.expressrepair.ca/why-doesnt-dishwasher-dispense-soap/
Jan 09, 2022 • Dishwashers
My Asko DW20.3 fills up the drip pan with a serious leak that happens when the wash cycle runs. How can I find exactly what is leaking and are parts available to repair this machine?
QUESTION: I just moved into a new apartment. The dishwasher is running normal but when it completes the wash cycle, my dishes are not clean and the detergent tablet is still there. The dishwasher is not dissolving the tablet. Maybe a little bit but about 80% of it is still there. I believe it gets hot water and runs normally. The apartment management said to use dishwasher cleaning tablets and not the powder soap. What can I do to try and get the tablet to dissolve? Any help you can provide would be great!
ANSWER: If your dishwasher hot water temperature is below 110F/115F, then it may not be hot enough to dissolve certain brands of detergent tablets. Be sure the water is HOT before you run the dishwasher. Run the hot water in the sink until it is very hot, then immediately run the dishwasher. Run the dishwasher on the longest, hottest cycle it has.
Also check that the spring opening action of the detergent dispenser door is working properly. If the detergent dispenser is too small a big detergent tablet may not be letting it open correctly. It may be jamming up the door. Try using a liquid or gel dish washing detergent if this is the case. There are many high quality liquid and gel dishwasher detergents on the market today. Liquid Cascade seems to be the best so give that a try. A powdered detergent will work too. Use a rinsing aid also as this will help remove spots even when the tablet may not be dissolving properly.
KEEP THE DISHWASHER DETERGENT DISPENSER CLEAN
If you are in an apartment, then most likely you do not have a high quality dishwasher. Knowing this, the dishwasher needs all the assistance it can get with the hottest water possible. You also need to be sure your dishwasher is clean at the bottom (removable strainer filter) where the pump and bottom washer arm is located. Be sure that it is clean and has hot water and this will be the best method to dissolve tablets. If you must use tablets, you can break them in half in the sink first. Place them in the dispenser and the hot water should make it easier to dissolve since the tablet is not as large.
You also need to be sure there is enough water for the pump to actually pump the water. To check this, start the dishwasher. Once you hear it running, open the dishwasher and be sure there is hot water and enough of it. If there is not much water in the dishwasher it may not be getting much water to the pump. When you open the door while it is running, check the water level at the bottom of the washer. If there is not much water at the bottom, then it may not be getting enough water to clean dishes and dissolve the tablet. Clean the filter at the bottom of the dishwasher to help the pump get the water more efficiently.
DISHWASHER PARTS IDENTIFICATION
If all else fails, you may have an old worn out dishwasher. The pump may be bad. Possibly your water heater is set to low. Your water heater should be set right around 120F. This will ensure that your dishwasher is getting the correct water temperature to effectively clean dishes and dissolve the tablet. If in an apartment, let the management know you are having this issue and they SHOULD resolve it.
Do you know of another way to assist a dishwasher to dissolve a detergent tablet? Please leave a comment below.
1helpful
Dishwasher tablet does not dissolve so crockery not clean
Hello, M Cruse -
There are several situations which can result in the dishwasher detergent table not dissolving completely.
First, make sure your dishwasher detergent tablet isn't the kind that has to be removed from a cellophane type wrapping before placing in the dishwasher. I mention this because my husband does not always purchase the same brand of dishwasher detergent tablets. Some are not the kind with plastic which dissolves in the hot water of the dishwasher.
I think the information here:
https://removeandreplace.com/2015/05/15/dishwasher-not-dissolving-detergent-or-tablet-how-to-fix/
covers all the reasons why the dishwasher detergent tablet may not dissolve completely.
We have the problem that the detergent dispenser often "traps" the tablet. We reside in a rental and the landlord has not chosen to replace the dishwasher with a newer model, so we just toss the tablet into the bottom of the dishwasher.
Note: I think purchasing a gel dishwasher detergent would be better, but The Husband likes the tablets. Sigh . . .
Best wishes.
Feb 04, 2018 • Dishwashers
Our dishwasher is not dissolving the soap. Has anyone else had this issue and does anyone know how to fix this problem?
Try using a liquid dishwasher detergent.
Also, if you are using dry detergent (that is not pre-measured in pods, etc.), you may be overfilling the detergent dispenser. When the dry detergent gets wet, it swells and causes the detergent dispenser door to stick.
3helpful
2answers
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
7helpful
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
1helpful
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
1helpful
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
ZANUSSI 695 Integrated Dishwasher
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
