power steering pumps ,electric ? i have swopped bits over between these units before now with varying degrees of sucess ,even the renault uses the same pump but all i can advise is strip the unit and see ?? as for the wiring then anything is possible but these cars and a few others do suffer with the ignition switch which is made by clauser ,Just buy anbother one 194 euros as a complete kit with the door locks and fuel cap as this kit is cheaper in the dealers than a individuel item ,dont forget to change the chip out of the old key for the new key
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7 000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
Hello! The only way to acquire your code is to take your vehicle to an authorized Citreon dealer. Using the VIN# they will, as a courtesy, retrieve the code from their system.
98 citreon saxo 1.6 8valve,, won start.if it do start ,it runs for 3seconds, fuel pressure at rail is only 2to3pounds this modle have not got pressure regulator on the rail the code reader tells me no code in memory, any ideas ? john
under the steering wheel there is a browny orange block connector, this needs to be cut out of the circuit and the correct colours joined to each other. this is a common problem on citroen saxos i have encountered this problem myself .
