Scanner was working fine, downloaded new driver now "error 2019" unable to communicate with the TWAIN device. I have completely uninstalled and reinstalled all of the original software. And still receiving this error.
Try this links:
Note: You must uninstall your current driver and OneTouch software to install and updated.driver.
https://www.xeroxscanners.com/Knowledgebase/Articles/VIS1053%20-%20Step%203%20Reinstall%20the%20Scanner%20Driver.asp
https://www.xeroxscanners.com/Knowledgebase/Articles/VIS1056%20-%20Step%206%20Contact%20Support.asp
SOURCE: error code 2019
Step 1 - Verify the scanner's power and connection
Step 2 - Redetect the scanner in device manager
If there is no Found New Hardware message when the scanner is turned back on and the scanner is not listed in Device Manager under Imaging Devices or Other Devices, this typically means the scanner is not communicating correctly with the computer. Try plugging the scanner into a different USB port or using a different USB cable.
The scanner may be listed as any of the following:
SOURCE: "Unable to open TWAIN server" Please assist
For any device to work you need 'drivers'. It is difficult to find a driver for an old product with a new OS like vista. You can try to get drivers for XP or Win2000 and use them.
S. Mohan
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well, Printer Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook. You may receive some communication error messages if you are using a "PORT REPLICATOR CABLE"( USB TO PARALLEL connector). The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at [email protected] if you need further assistance.
Bye.
