Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
