Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony 46 KDL 46S2000 screen went black and the
Sony 46 KDL 46S2000 LCD screen went black and the standby lite is blinking no picture at all nothing works
  • 1 more comment
  • Anonymous Jan 23, 2010
    The set came on for about 4 sec. then made a click sound like it was turning off then the screen went Black. The standby light came on and is blinking 4 times then goes off and blinks 4 times. Nothing is working at all. I unpluged the set over night same problem I even tried to reset the TV from the manual and still nothing. Black screen and standby light is blinking 4 times... What could it be.. The set was working fine for the last 4 years great picture no problems before yesterday when the screen went black??
    you can reach me at ssmajones4@comcast.net Thank You
  • Alexander  Moore
    Alexander Moore May 11, 2010
    need more info: if you try to restart the set, would it have a screen light up for a second? Did you try to unplug and plug the set back? Was it acting up before and ,then quit?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 49 Answers
You can referen the article:
How to Fix a Black Screen at Startup
maybe it can give your some help
Posted on Mar 05, 2010
6ya staff
SOURCE:
Standby light flashes 4 times
One option to try is to try to factory reset the tv, to do this turn the tv on hold the Down Arrow on the remote and while doing this press the power button then release the down arrow button.
Bit of info on your issue
* Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Trend to find everything
Oct 04, 2014 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My lcd flat screen plastma tv screen got broken.i want to know is is repearable.
KDL-46S2000 Panel cost approx $1500 +$3000 core charge, Part # 1-802-100-31.
Parts reference: Andrews electronics, 800 289 0300.
May 08, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Jan 24, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a 52 inch sony bravia. turn it on and i hear a buzzing sound then the red standby light blinks 13 times.....what gives. I need help
Sounds like the lamp is blown. Check your manual to see what the blinking lights mean and how to check the lamp.
Jan 16, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
The vertical screen cannot be adjusted. Watching football games the score cannot be seen at the top of the screen. changing vertical center and vertical size has no effect
You question shows its Sony KDL-46S2000 lcd tv so adjust screen format like zoom etc to adjust picture size best fits in screen.
Screen format option is available in Menu.
Dec 06, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Black streaks appear verticaly on my screen.
hi this might be happening because of your cable if that isnt the problem then you will have to contact sony and let them know what is happening with tv
Jan 10, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
1,404 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
