Vizio VP322 32 in. Plasma TV Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio 32 vp322
Vizio 32'' plamsa at first took a long time to come on now will not come on at all.
Chi Chu
Level 3:
  • Vizio Master 8,457 Answers
  • Posted on Jan 23, 2010
Chi Chu
Vizio Master
Level 3:
Answers
8457
Questions
0
Helped
2820434
Points
26282
Power board is dead.Must be replaced,to get power back.Tries Shopjimmy.com,Ebay.com for the power board part.
My Vizio Vp322 will not respond to side input buttons. Also, when you press the menu button, it continually scrolls through the menu
thats almost always caused by a bad main board. Replaceing the main board should solve the issue you can get a replacement main board from www.tvcircuitboards.com
Vp322 hdtv10a have picture but no sound, what board is it?
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Remote control code for vizio vw26L
BEADSRULE, IT WORKED! I HAVE A VERY OLD ALLFORONE REMOTE AND THE LG 0178 CODE WORKED ON MY VIZIO TV THANK YOU! ;)
Sound went out on vizio
Help people with this problems many times.Reset ur tv,by unplug,replug it an hour later.Go to the tv menu,go to AUDIO setting go down to reset,press that to reset,will return it back to factory setting the audio well return.
3helpful
Power turned on & off by itself then power died completely
Had the same thing. Bad capacitors in power module.
9helpful
5answers
It won't turn on
I replaced 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
4helpful
My vizio wont come on its like its no power
The Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory
Does not turn on at first only clicks and flaskes
Where did you bought the TV from? Your TV still under warranty. Give Vizio a call, they will take care of it.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
