Heating & Cooling Logo
Posted on Jan 23, 2010
Compressor is stopping a few minutes after starting. i sometimes get it to work again by turning it off, pressing the reset button on the external unit, leaving it off for a few minutes and turn it on again. Our aircon is a Carrier Reverse Cycle ducted system - model 38UBL022/40UBL022.
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Jan 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
5531
Points
38
Try cleaning coils and filter
Dometic B2200. Compressor don't stopp
check compressor relay possible stuck on
2helpful
2answers
I have lost the instructions on how to set the time and date for a digital multi clock GH120A, please tell me how
https://m.blog.naver.com/PostView.nhn?blogId=mobile_app_top&logNo=220570562627&proxyReferer=https://translate.googleusercontent.com/translate_p?hl=en&prev=search&sl=ko&u=http://m.blog.naver.com/mobile_app_top/220570562627&depth=1&rurl=translate.google.com&sp=nmt4&xid=25657,15700022,15700186,15700191,15700256,15700259&usg=ALkJrhgAAAAAXRePT_E1IEH3FJYm7TS9LAEefyLAgoL5
Visual Think December 16, 2013 23:09
Add neighbors Body Other Functions
For the GH120A / GH-120A,
Multi stopwatch / table clock / stopwatch / stopwatch timer, etc.,
Just have an alarm function, a small digital watch with a stopwatch function.
This watch,
I think there are so many users that I can often see at someone's house, and I think it will be difficult to find the manual later.
sometimes,
I do not think it's inconvenient for someone to read this manual.
Below is the manual.
1. Button Description
- MODE : Each time the button is pressed, the sequence changes as follows.
; Current time ? stopwatch ? alarm setting ? time / day / calendar setting ? current time
- RESET : When the stopwatch function is activated
; STOPWATCH STOP - RESET STOPPER TO 00:00
; When the stopwatch is started - On the screen, the first stop is displayed one second, and the second stopwatch is running internally.
(It can be useful when measuring 1st and 2nd records when running 100m)
At this time, press the START / STOP button and press the RESET button again to display the last second
- START / STOP
; When the stopwatch function is activated - Start or stop the stopwatch function
; Time display function - Date display
; When setting alarm or time - Function to adjust set value (time / minute increase, date increase, etc.)
- Back button
; Press once to activate the backlight for 3 seconds (keep lighting while pressing)
- Back round switch
; When the switch is turned off, the alarm sound and the button sound are turned ON (ON character display state is ON)
; When the switch is raised, the alarm sound and the button sound are turned off (OFF character is OFF)
2. Feature Description
- current time / date / day setting
; Press MODE button 3 times in time display mode
? If you press START button,
? Pressing the RESET button (minute blinking), pressing the START button increases the minute
? Pressing the RESET button (time flickering, pressing the START button increases the time,
Change AM / PM after 12 hours
? Press RESET button (date blinking), START button
? Pressing the RESET button (blinking the month), START button
? Pressing the RESET button (blinking day), START button
? Press the MODE button to complete the setting.
- Stopwatch (stopwatch)
; Changed to the stopwatch function with the MODE button pressed once (0:00:00) in the time display mode.
? Press the START / STOP button to turn the stopwatch on and off
(However, if the RESET button is pressed during the stopwatch operation, the stopwatch stops, but internally,
The second clock is still running, press the START / STOP button once,
When the RESET button is pressed, the second stopwatch is stopped)
- Alarm function
; Press the MODE button twice in the time display mode (the flashing hour part appears on the screen)
? Timed by START / STOP button
? Pressing the RESET button (blinks for a minute)
? Split by START / STOP button
? Press the MODE button to enter the time display mode (create a bell shape on the screen)
; Disable / set alarm function
If the RESET button and the START / STOP button are touched simultaneously, the bell disappears and the alarm is canceled.
(Press again the RESET button and START / STOP button again to display the bell shape and activate the alarm function)
- SNOOZE
; When the alarm sounds, pressing the RESET button completely turns off the alarm,
; When you press the START / STOP button (bell blinks)
; After the alarm is turned off for a while, the alarm sounds every 4 to 5 minutes.
; To turn off the alarm completely, press the RESET button.
- Hourly time signal notification
; It is a function that sounds once every hour,
; While in the time display mode, press the MODE button while holding down the RESET button.
; When pressed,
; If all the day of the week display is visible on the screen, the time notification function is ON,
; OFF state if no day of the week is displayed on the screen
- Backlight function
; Press the round button on the back once to activate the gauge for about 3 seconds (press and hold to continue)
- 12/24 time system change
; Press MODE button 3 times (second blinking)
? Press the RESET button twice (at the time)
? Press the START / STOP button once to alternately display AM / PM / 24 hour display with increasing time
? Press the MODE button after setting is completed.
This concludes the GH120A User Manual (manual) posting.
1helpful
Ipod disabled
Like all electronic devices, iPods sometimes freeze and become unresponsive.
Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working.
All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated.
An iPod will appear frozen and unresponsive if this feature is activated.
A lock symbol will appear on your iPod's screen if it is in Hold mode.
Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button.
Press both buttons at the same time and hold them for up to 8 seconds.
Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen.
Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod.
Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it.
Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons.
Connect your iPod to its powerblock or a computer if it is still frozen.
Wait 5 minutes and then try to reset it.
Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
2nd gen ipod shuffle non-responsive
Step 1:
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
SECURITY CODE MODEL NO A1137
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
My ipod touch 4th generations says ipod disabled connect to itunes, but screen is locked
1helpful
How do I fix my frozen e reader
1helpful
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
3helpful
2answers
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
