Refrigerators Logo
Posted on Feb 14, 2008
Deli drawer Fride deli drawer falls down constantly , will not stay in track, why? Can this be fixed?
  • 1 more comment
  • tt869 Oct 04, 2008
    I have Kenmore 106.54606300 same happens with deli drawer... it is not wide enough to fit the tracks will....
    Also, the tracks that are hung from the brackets that support the glass shelf keep falling out!!! There must be some kind of "locks" available to keep the tracks in place????
    Thanks, Tom
  • Anonymous May 11, 2010
    well first off you need to post a model number so we can see what you have 2nd you need to be as specific on your problem
  • PATRIA FRIAS-COLON
    PATRIA FRIAS-COLON Nov 05, 2013
    model # GSL22JFPHBS; serial #ZG224522
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 11, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1683
Points
0
The tracks are too wide at the rear. Just remove the small drawers and the shelf above the deli drawer. The tracks can be shimmed in an 1/8 inch or so at the rear. Ours is now perfect. I had to point t out to the repair guy, but he agreed and got right on it.
A
Anonymous
Dear Master Tech: The model number is GLRT13TEB3. The problem is every time you try to open the deli drawer it falls straight down.
It is as if the tracks to hold it are too far apart? Also the tracks are part of the glass shelf.
Any help with this annoying problem would be much appreciated.
Thank-you, Nanc T.
Anyone have a fix for the full-length deli drawer constantly falling down? Maytag 20.5 cu. ft. Black Ice Top-Freezer Refrigerator Model Number: MRT311FFFE
I would remove the track, clean both surfaces and stick it with clear silicone or superglue Gel. Leave it 24 hours to set.
Deli drawer is stuck. Off-track. How to fix without breaking?
The Drawer might be frozen in the unit
Take out your food from the freezer and let it defrost for an hour or two then you might be able to get the drawer back on track with just a little tug.
Will the deli drawer work properly without the glass door/lid? The pin broke off the right side and can't be fixed ... plastic broke off the actual drawer roller on the right. Cheap plastic ... disapp
Call in a repair man, it shouldn't cost that much. Yes, your food will be effected without that plastic door, as the drawer has controls and cold settings just for deli items. You need a special glue for cold. I'd call in a repair man, or order a new drawer replacement from the manufacturer.
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Broken shelf
The small meat or deli drawer tracks show to be avail for replacement as a left and right part. Front and rear screws are shown for each track. Since these parts are shown by themselves, the parts should be replaceable alone. Part# 63001371 is the left track Part# 63001372 is the right. About $5.00 each. The full shelf is a Part# 67001532 @ about $31.00. Pleazer Appliance...
2answers
Kenmore Refrigerator 596.73503200 deli drawer cover hinge pin on right side broke off. Part #?
I would direct you to this link to find the part number you're looking for. I do not have one of these units to look at so am unsure which specific piece you'll need to replace.
Model 59673503200 KENMORE ELITE KENMORE REFRIGERATOR Parts
Deli drawer
You don't say brand or size but normally if you remove drawer and shelf above it, unless clips are broken(you can order new) install the clips, install shelf and install drawer that no longer falls down.
Joe Don
1helpful
Drawer beneath oven keeps falling off it's little wheels
I sympathise with your problem and sorry about your broken toe.. The drawer sits in a slide and the rollers on the drawer travel inside the track.. If your husband is reasonable handy ( or you ) ..empty the drawer and try to get the wheels into the track on the oven.. this process is similar to that used on some kuchen cabinet drawers and furniture so it is no different..just hard to see or get it started..
With the drawer out of the oven..use a flashlight and examine the track to make sure it is not damaged ( do the same thing on the mating slide/rollers of the drawer)..
If possible, can you return to the place you bought it from and have them show you how to do it? They owe you at least that much... Good luck and take care of that toe...
2answers
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
