We have the blue spots starting on the screen and then they went increasing at the point the tv looks like having a sky full of stars at night. Right now we also have a yellowish block patern from the center of the tv impossed over the picture. We really don't know if it is better to buy a new tv or to fix this one.
SOURCE: bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
SOURCE: Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
SOURCE: Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
SOURCE: I have a sony KDF - 60 WF655 projection tv
SONY HAD A RECALL ON THE KDF50,52,55,AND60. CALL SONY
SOURCE: blue color going up from down right corner toward center of scre
Your optical block is going bad. Contact sony support with your model and serial number. They sometimes warranty these even after the 1yr warranty has expired.
