Whirlpool AWM8163 Front Load Washer Logo
Posted on Jan 23, 2010
F11 error lights flash then stops at last spin . I did clean the filter and took some coins out Whirlpool AWM8163 washer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
366
Points
The F11 fault is the motor. I have had this issue myself and found that replacing the contact brushes solved this. The brushes on most electric motors are made from carbon, and wear down with use. They are spring loaded but have a limited life span. These are also cheap to purchase.
2answers
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
2helpful
2answers
My Whirlpool AWM 8163 is flashing FP (orPF). Anybody have any ideas? Many thanks
You need to clean your filter once you have drained the water out look in the hole you will see a little impellor there might be an object loged in
Clean pump light comes on but cannot locate it, have cleaned the filter but still not working AWOD4305
The filter is part of the pump right at the front of the machine.
Maybe the pipe waste is blocked?
jb
2helpful
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
The machine runs until the spin cycle then stops
That means that you need to have the door latch replaced, a bad door sensor is preventing the washer from spinning.
Try first unjamming the latch with a stick, like a pencil for example.
If that does not work, replace the door latch.
5helpful
2answers
Error code f35 on my washer
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Spin
Electrical module fault
The “Spin Speed” indicator and the “Start
Delay”
option are flashing and an audible tone
sounds. The display shows “F4” to “F16”.
Switch off the appliance. Select a programme
and press the “Start/Pause” button once
again.
The programme will continue.
If the fault re-occurs, contact After Sales
Service (see “After-Sales Service”).
the user man can be found here
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Calypso Washing Machine
There are two places a coin could be that will cause a noise. Either in the basket under the nutator or in the pump. If you hear the noise after the basket stops from the spin, look under the nutator, if you hear it during the cycle, check the pump. If you only hear the noise during the agitation, not the spin cycle, you may have a u-joint going out.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
