LG 37LC7D 37 in. LCD HDTV Logo
Anonymous Posted on Jan 23, 2010
My LG 37LC7D just started shutting off by it self and when it happens it sounds like a small pop.
  • Anonymous Jan 24, 2010
    Thank you!
Ginko
Level 3:
  • LG Master 19,396 Answers
  • Posted on Jan 23, 2010
Ginko
LG Master
Level 3:
Answers
19396
Questions
25
Helped
8074483
Points
55462
Hi.
It is likely a capacitor on PSU that is starting to blow. The TV must be taken apart by a technician, tested and fixed replacing the faulty board, of the component.
If it is PSU, for example, he will either replace the set of capacitors, or replace the whole board.
More faults, concerning different parts can cause the TV shutting down after a pop noise. The TV must be disassembled and tested to find out.
The best thing to do is contacting LG at the number listed on the owners manual. They will give you instructions on how to get it serviced.
Here parts: ShopJimmy - 37LC7D
Anonymous
Level 2:
  • Expert 148 Answers
  • Posted on Feb 03, 2010
Anonymous
Expert
Level 2:
Answers
148
Questions
0
Helped
85451
Points
618
I agree, this is a powerboard problem, more exactly, a capacitor problem, I would like , in detail, explain how to diagnose and repair this problem....Good luck and please rate!..The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! my LG 37LC7D just started - 7ba1129.jpg
1helpful
No sound on an lg 37lc7d tv?
Your main pcb could still have gotten damaged due to the defective caps. The reason you still have audio through the optical is because it is a digital signal only. It is not running through the audio amplifier on the main board. I would suspect either the main pcb or the speakers them self.
4helpful
2answers
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Green specs in dark areas on my LG - 37LC7D tv. After being on for a while, the green specs disappear. How can this be fixed and is this building up towards other bigger problems?
Most likely it is the LCD Panel causing this and it could get worse. The only fix is to replace the LCD Panel and if it is out of warranty it would be too costly. We are talking replacement cost of $900.00 for the part its self.
Skyassoc
I have a lg 37lc7d will shut its self off
When it shuts off does the power light stay on like the unit is still on?If yes,try shining a bright flashlight at the screen and see if you can see any video.If you can your power and main boards are ok.you would then probably need an inverter board or panel.If it is shutting completely off you need a main total assembly since you have already replaced the power supply.The main total assembly is avery common issue on lg lcd tv's.
1helpful
I have a 37 inc LG LCD TV. While watching it the TV made a loud pop noise and the screen went black. We lost both the screen and sound. Tried it again this morning and after 2 minutes the same thing...
you have blown an internal fuse you might be suprized to learn that ther is someone veryclose to you who might be able to fix it a lot of people who fix tv's work from home bassically you just neeed ot repalce a small circut board inside it
just google and try to find them
take tc back it should sill be under warenty if they refuse you can say t othem this is not fit for its purpose and force them to fix or replace it
1helpful
I have an LG 37LC7D. Never had a problem until yesterday. I turned on the tv and after about 10-15 minutes, it started to flicker, slowly at first, then it got faster and louder and shut itself off. I was...
You have a component breaking down electrically, a dry joint on a circuit board or it needs a good cleaning of all the electrical parts. To fix the circuit board or components, you will have to take it to a TV repair store. But first, try cleaning it. Disconnect the electrical supply and take off the rear cover. Using a fiber dust remover or a vacuum cleaner, remove any build up of dust and hair from anywhere inside the TV, paying particular attention to the cooling fan intake and ducting. Be careful not to damage any fragile components .
Good luck.
6helpful
2answers
LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
