Do you have a picture with just normal playback of VCR? If the answer is no, then it sounds like the head might need cleaning. Use Servisol video 40 see image below:
Try a cleaning tape in the VCR. If the pictures both come ut of the same connector then the VCR may be in need of cleaning. Also can you see a picture 'through' the vcr, if you wanted to record on the vcr? Have you tried recording? I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
According to my Satellite provider tech support. More and more channels are being encoded so that recording equipment cannot capture the signals to prevent piracy. I know the premium channels use this technique now. I would call and ask tech support if there is any copy restrictions in place that would affect your VCR recording before doing any further trouble shooting on the VCR. If you can play pack a prerecorded movie fine with your VCR then it should also record fine. Also try watching the channel through the VCR tuner and I bet you will see the same pattern. The VCR can only record the signal it is given.
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
