Question about Compaq Presario 5000 PC Desktop
Red light flashing on power button
Hi I have a Compaq Presario 5000 and it will not switch on - when I press the power switch a red light flashes and nothing happens - any ideas? my compaq computer went in standby mode with a red light blinking. I turned it off and back on. now i cannot get in to work. any solutions?
It may be a power supply problem. Wires are thin enough to crack, if this happens when the power supply is cold the system will boot but when turned on heat is produced causing the wire to ope., hence the flash of red light. Try another power supply before buying one - easy to replace.
Posted on Feb 18, 2008
    Sergeant:
    Champion:
  • 317 Answers
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Posted on Feb 14, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 67 Answers
SOURCE: stuck on safe mode
goto start --> run --> type msconfig --> there should be a option to change to the boot tab, under boot options tick safe mode off. and press apply and then ok and restart your computer
Posted on Jan 24, 2009
WHY DOES A RED LIGHT FLASH 4 TIMES THEN SHUTS OFF ON MY HP COMPAQ
Hi:
Here is what I would do...
Turn the PC off and unplug it. Then press the power button to drain any residual power from the motherboard.
1. Remove and reseat the memory module(s). Restart the PC.
2. If removing and reseating the memory module(s) doesn't work, if you have more than one memory module installed, remove all but one, and start the PC.
Test each memory module one at a time, until you find the one that is bad.
If none of that works, check for bulging and leaking capacitors on the motherboard. These may be particularly noticeable around the processor area.
Apr 27, 2014 | Compaq Presario 5000 PC Desktop
Press start button, fan trys to start, green light comes on then changes to a red flashing light
If your fan is trying to start up but won't, your system is going to give you a warning and most likely shut down. Make sure you have good connection for fan power and that it is clean and can turn freely. You may want to cosider replacing the fan.
Apr 09, 2011 | Compaq Presario 5000 PC Desktop
Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Jun 29, 2010 | Compaq Presario 5000 PC Desktop
I unplugged my COMPAQ Presario computer to bring it downstairs tonight because we are getting ready to move and now it won't turn back on. It is plugged in and the green light in the back is flashing, but...
flip the red switch a couple on the back it should be on the power supply and leave it plugged in, an you need something to flip it with maybe a screw driver
Jun 13, 2010 | Compaq Presario 5000 PC Desktop
Cpu not powering press on button lights flash fans turn for a sec
It a issue with the power supply or the SMPS. Change the SMPS of same capacity and then it should work..............sodeep
Jul 30, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 won't turn on
hi,
The machine is getting the power but no display.This seems a RAM or motherboard issue.
1.Press and release NUM Lock after turning on and if it is responding this is a RAM issue and if not then the mainboard issue but before all refix the RAM once.
Thank You.
May 30, 2009 | HP Compaq Presario SR1830NX PC Desktop
I Have A Compaq Presario That Will Not Power Up.
It sounds like your power supply unit as some leaky components, normally the bad powersupply unit show these types of symptoms. Try borrowing a powersupply unit from a friend that is similar to yours and replace to check if the powersupply unit is the culprit. If cornfirm PSU, than you neet to get yours fixed.
Nov 11, 2008 | Compaq Presario 5000 PC Desktop
Red light flashing on power button (2)
I just tried the link again and it worked fine. Let me walk you through the links I clicked to get there: Goto -> http://www.hp.com/ Click Support & Troubleshooting Enter Presario 5000 in the Select a task and enter a product name/number section and make sure See support and troubleshooting information is checked. Click your model (Any Presario 5000 should do. I chose the Compaq Presario S5000T Desktop PC). Click on Solve a problem. Click on Boot-up / power / port issues. Click on Troubleshooting Power Supply Issues. And there you go.
Sep 26, 2006 | Compaq Presario 5000 PC Desktop
how I solve this issue of a customer of mine.
replaced power supply and one memory stick was faulty
lesson learned: check the obvious first.. .Powersupply.. if problems persists... check your ram... if you have 2 sticks of ram,, try reseating and using one at a time or swap with known good memory.
Sep 13, 2006 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
764 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
