Yes, you can manually clean the printhead. I can't provide step by step instructions, but the print head is the piece that your ink cartridges go into. There is probably a lever that holds it locaked into place. You will want to take out the ink, then open the lever and remove the print head. Then clean where the ink cartridges sit, then gently clean any coppor contacts you see and then clean the print nozzles on the bottom of the print head. Do all of this with distilled water. Dry completely and re-install along with your ink.
If this doesn't solve the issue, you can buy replacement print heads.
SOURCE: paper jam in brother MFC 240C
the paper ripped at the corner in little pices and it is jamed in the printer how can I remove it
SOURCE: Brother MFC-240C Error 30/50
The problem with this machine is that you need to take off the top tilting cover, then remove several screws to take off the lower top cover. The print head is then visible. If you don't have experience, I wouldn't recommend it. You can ship it to me if you like. We are a Brother service center for 18 years. I'm in CT.
SOURCE: Brother MFC-240C Control Center
Follow the instructions on this page and reinstall your driver for Vista.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/002700/dlf002700.html?reg=us&c=us&lang=en&prod=mfc240c_all&type2=1&os=74&flang=8&dlid=dlf002700
Hope it helps!
SOURCE: Over-ride out of ink message Brother MFC-240C
Yes, you can cut a small piece of electrical tape and place it over the window on the inside edge of the cartridge. it has to wrap around the window tightly.
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
