Tip & How-To about Computers & Internet
You might encounter something like "Access Denied", "The file has beentransferred to another location or deleted" or some other errors whilecopying your files.
This is a typical problem to those Windows XP users. So what they do isjust recopy all the files again but they will exclude the one with theerror.
What if you have virus that you are in random folders that can't be moved/copied?
What if your old files that you don't need have random access denied files?
What if and what if?
How to continue copying files and exclude the files with error?
Here's how you do it.
What is xcopy?
Copies files and directory trees.
How to use xcopy?
XCOPY source [destination] [/A | /M] [/D[:date]] [/P] [/S [/E]] [/V] [/W]
[/C] [/I] [/Q] [/F] [/L] [/G] [/H] [/R] [/T] [/U]
[/K] [/N] [/O] [/X] [/Y] [/-Y] [/Z] [/B]
[/EXCLUDE:file1[+file2][+file3]...]
See the REFERENCE below for the detailed meaning
Step 1.
Click Start then click Run...(Or Simply Press Windows key+R)
Step 2.
type "xcopy [source] [destination]"
Sample 1: (For single File ONLY)
xcopy C:/Windows/System32/userint.exe E:/Backup
Sample 2: (For folder including their sub folders)
xcopy C:/Windows E:/BackupWIndows /S
or
xcopy C:/Windows E:/BackupWIndows /E
Sample 3: (For Continue Copying even Error Occurs)
xcopy C:/Windows E:/BackupWIndows /S /C
Sample 4: (For allowing copying encrypted files)
xcopy C:/Windows E:/BackupWIndows /S /G
Note: You can combine the rules/options that you like.
That's it! you now have a way to copy files that are protected, accessdenied, or even those that are encrypted. Hope This tip helps you. ^^
REFERENCE:
What are the use of the options?
source Specifies the file(s) to copy.
destination Specifies the location and/or name of new files.
/A Copies only files with the archive attribute set,
doesn't change the attribute.
/M Copies only files with the archive attribute set,
turns off the archive attribute.
/D:m-d-y Copies files changed on or after the specified date.
If no date is given, copies only those files whose
source time is newer than the destination time.
Specifies a list of files containing strings. Each string
should be in a separate line in the files. When any of the
strings match any part of the absolute path of the file to be
copied, that file will be excluded from being copied. For
example, specifying a string like obj or .obj will exclude
all files underneath the directory obj or all files with the
.obj extension respectively.
/P Prompts you before creating each destination file.
/S Copies directories and subdirectories except empty ones.
/E Copies directories and subdirectories, including empty ones.
Same as /S /E. May be used to modify /T.
/V Verifies the size of each new file.
/W Prompts you to press a key before copying.
/C Continues copying even if errors occur.
/I If destination does not exist and copying more than one file,
assumes that destination must be a directory.
/Q Does not display file names while copying.
/F Displays full source and destination file names while copying.
/L Displays files that would be copied.
/G Allows the copying of encrypted files to destination that does
not support encryption.
/H Copies hidden and system files also.
/R Overwrites read-only files.
/T Creates directory structure, but does not copy files. Does not
include empty directories or subdirectories. /T /E includes
empty directories and subdirectories.
/U Copies only files that already exist in destination.
/K Copies attributes. Normal Xcopy will reset read-only attributes.
/N Copies using the generated short names.
/O Copies file ownership and ACL information.
/X Copies file audit settings (implies /O).
/Y Suppresses prompting to confirm you want to overwrite an
existing destination file.
/-Y Causes prompting to confirm you want to overwrite an
/Z Copies networked files in restartable mode.
/B Copies the Symbolic Link itself versus the target of the link.
/J Copies using unbuffered I/O. Recommended for very large files.
The switch /Y may be preset in the COPYCMD environment variable.
This may be overridden with /-Y on the command line.
Visit redbullet05.blogspot.com for more troubleshooting guides. ^^
While trying to retrieve the URL: http://www.youtube.com/?
The following error was encountered:
