Why do the clothes in my duet washer come out soaking ?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The
filter on your pump is probably clogged with lint and stuff. You have to remove
the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain
pipe you see. The white filter cover is right in front. Get yourself a good
plastic bag to collect water. Unscrew the filter cover and twist the filter
out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On
some models the filter is located ‘inside’ the big hose from the bottom of the
tub. This takes more time to clean.
Pl rate me ‘very helpful’ for the free help!
