Indesit W 123 Front Load Washer Logo
Posted on Jul 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Indesit moon not spinning as it should
Hi
my Indesit Moon does not seem to be spinning properly. At the end of the cycle, the sheet and duvet cover i'd washed were still very wet. As I'm sure you know, there isn't a separate spin cycle on this type of machine (it's major design flaw as far as I'm concerned) so there is no way of spinning it a second time. Is this a common problem, and can anything be done about it? thanks in advance.
paul
Level 3:
  • Master 825 Answers
  • Posted on Jul 24, 2017
paul
Master
Level 3:
Answers
825
Questions
0
Helped
174098
Points
2202
My machine is similar...............but has an extra rinse button which adds 5 minits to the wash.....but spins faster to get rid of extra water...............see if you have extra rinse option......
cheers
2 Related Answers
Bob Gemmell
Bobby G
  • 212 Answers
  • Posted on May 29, 2009
SOURCE: I need to replace the seal round the door but cannot remove the old one
Take the top panel off by removing the two screws underneath the lid at the rear and look down inside towards the front door edge of the drum you will see a very large metal hose clips holds the door seal on. A screwdriver will loosen the clip then the clip will slip off and then the seal can be removed and replaced
Anonymous
  • Posted on Jun 06, 2010
SOURCE: Have the Indesit Moon washing machine and it will
when i purchased this machine i too had problems with machine getting stuck in cycles (mainly the 60deg)for hours and black marks apprearing on seal. when i looked into it i was told to check the height of the outlet hose. mine was too low down the pipe which causes the machine to cyphon. water is going out of the machine as soon as it is put in. this machine has an automatic rinse feature which will keep rinsing until all detergent has been removed from clothes. if the water is going straight out then the machine cannot rinse so tries to fill again (neverending cycle. also meant that i could not successfully wash on 60deg. bacteria thrives in lower tempretures hence the black mould on seal. after adjusting the outlep pipe the machine has worked like a dream. i also do a service wash once a month. run machine on hottest wash with no clothes in using bio powder. this cleans out the machine and kills any lingering bacteria. it has to be done with powder though because it contains bleaching agents. no smells now. hope this helps all those having problems.
Does the New Moon reset the days counted back to zero when it appear?
Hi Sakhile,
This is a matter of preference and can differ from country/culture to country.
Traditionally (in English speaking countries), et al., the New Moon is exactly one half of the Lunar Cycle. That is to say around 14(+) days.
Normally one talks about the percentage of illumination, waxing (as the light "grows" across the face of the Moon, towards the Full Moon) or waning (as the light recedes in the direction of the New Moon).
It is praxis that the Moon's Cycle is divided into 4 phases of around 7 days each. Ergo: 7 days Waxing, 7 days Waning.
The number of days counted from the New Moon is called "The Moon's Age" and is counted upwards, "as an age".
The Moon and it's orbit is an entire science but I hope I have answered your question.
Happy Moon gazing!
2helpful
Hi When I try to take pictures of the moon at night, the all I get is bright light without any detail. The sensor seems overloaded and the image seems smudged. I have tried with the intelligent...
All automatic-exposure cameras try to render the scene as a middle gray. The moon is a small portion of the total image, so the camera concentrates on the sky. In trying to get enough light to make the sky go from black to gray, the moon gets completely overexposed. What you want is the moon properly exposed, even if that means the sky goes completely black.
For a full moon, you want the same exposure you would use at noon on a bright day. If you think about it for a moment, it becomes obvious. The full moon is simply a landscape at high noon. Unfortunately, the camera can't know that.
Set the camera to manual. Start with the "Sunny-16 Rule", which tells you to set the aperture to f/16 and the shutter speed to 1/ISO. So for example, set the ISO to 200, the aperture to f/16, and the shutter speed to 1/200. Look at the result on the screen and adjust the exposure as needed.
That was for a full moon. For other phases you may need to add exposure, but the "Sunny-16 Rule" will still give you a starting point.
I have the indesit moon washer. The red door lock light is flashing when i start the cycle which is stopping the washer from going. The door is locked properly and there is nothing caught in it.
Just sorted this problem out, wife said just b4 leaving for work,oh love the door on the washing machine wont open and theres a red light on,,OMG i thought, as she said she would find the instructions when she gets home, so i got the corless drill out and a big hammer,( not needed,) lol just turned the power off and after 2 mins the door unlocked and was able to get all the clean wifes undearware out, cheers all and hope this helps
I just bought a Miele s558 Silver Moon, seems like
good vacuums bags are very expensive and parts too
return it
3answers
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
