You can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
if the water comes out fairly rapidly you may need to replace the drain pump.
once the water has been removed you can open the door and remove the clothes.after everything is removed you need to remove both the hoses from the drain pump and look in it for any thing that will stop it from turning and or blocking the drain pump.
