Several PCs for my church are HP Compaq, Model dCMT computers, that have Nvidia Geforce4 MX 440 w video cards connected to ViewSonic VA712b monitors.
The display using the VGA connectors of the video card and the monitor is good. Using the DVI connectors of the video card and the monitor displays "Analog No signal!.
Are there any jumper settings on the card or in CMOS that I should be aware of?
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Testimonial: "Thanks! I found the monitors' user manual and read how to select the digital input from the monitors' Main Menu Screen. Thanks again!"
